I have the following problem the electrical designer specified a ground ring #4/0 around a new expansion area of an existing industrial building. The drawings indicates that this ground ring should be connected to the existing ground ring. The problem is that it can not be found. The new ground ring is going to be use only for security to connect a supplemental ground. The circuit comming from the existing MCC an electrical equipment ground.
The question is can I have this ground ring with out a connection to the existing ground ring? Article 250-54 states that a grounding electrode shall be permitted, but it can not be used as a sole equipment grounding conductor.
