I am working on a project where a customer wants to power a small control panel from 120VAC receptacle. He is trying to have the panel UL508A certified.
5x20mm fuses (UL Listed as supplementary) are spec'd out in his design.
There are a couple relays and timers inside the panel with a pushbutton and selector switch on the door. Outputs are two solenoid valves.
Would branch circuit protection be required inside the panel before the supplementary glass fuse?
