Do supplementary protectors (UL 1077) protect the wire? Is it ok to downsize a conductor if the proper branch rated protection is upstream of the supplementary protection?
For example if you have a 30amp branch rated protector up stream of a 10amp supplementary protector is it ok to size the wire according to the supplementary protector? Or do you size the conductor based on the load?
Thanks
Thanks
