jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Another supply issue over simple items. We often need these glue in box adaptors for tight spaces or thick walled PVC boxes where a male adaptor & locknut leave no threads for a standard plastic bushing. So, the supplier doesn’t have the glue ins, making the throat liner bushings necessary. You guessed it, they don’t have them either & have to order them. Some suppliers don’t even carry them at all.
I know these may not sell by the hundreds each day but they need to be available. They are small and relatively cheap, so they wouldn’t be hard to keep in stock. If I were still contracting regularly, I would order some of these things ahead, in small numbers, just to have them when needed.
Another frustrating item is LED bulbs. They are used a lot to bypass ballasts in HID & fluorescent lights. This will happen more & more. I had a few times where I went all over town & no one had the right bulbs. I gave a former boss a file I started on what customers used what bulbs. I talked with a supplier today who said they also deal with manufacturers changing or discontinuing models on short notice. If you buy for any kind of building, wise to find the right bulbs & order as many as you can afford and safely store.
I understand items such as floor boxes. There are many styles, some very expensive. I wouldn’t keep many of those either.
