We have a situation where a customer is using 120/208v 3? 4wire rated service entrance equipment which will be connected to a 240v 3? 3wire corner grounded closed delta utility supply. Terminating A? and C? to their associated bus, B? to the ?neutral? bus which grounds the service and not using B? bus. Now you have 240v to ground on two of the three phases and 240v phase to phase of the equipment which is only labeled for 120v to ground, 208v phase to phase. This equipment will work but doesn?t need to be listed for such use? Does NEC touch base on voltage ratings? Appreciate any assistance.
