[1996 NEC]
340-5. Uses Not Permitted. Type TC tray cable shall not be
(1) installed where they will be exposed to physical damage; (2)
installed as open cable on brackets or cleats; (3) used where
exposed to direct rays of the sun, unless identified as sunlight
resistant; (4) direct buried, unless identified for such use.
Exception: In industrial establishments where the conditions of
maintenance and supervision ensure that only qualified persons will
service the installation, and where the cable is not subject to physical
damage, Type TC tray cable that complies with the crush and
impact requirements of Type MC cable and is identified for such
use shall be permitted as open wiring between the cable tray and the
utilization equipment in lengths not to exceed 50 ft (15.24 m). The
cable shall be supported and secured at intervals not exceeding 6 ft
(1.83 m). Equipment grounding between the cable tray and the utilization
equipment shall be provided by an equipment grounding
conductor within the cable
[1999 NEC]
340-4. Use Permitted. Type TC tray cable shall be permitted
to be used in the following.
(6) In industrial establishments where the conditions maintenance and supervision ensure that only qualified persons will service the installation, and where the cable is not subject to physical damage, Type TC tray cable that complies with the crush and impact requirements of Type MC cable and is identified for such use shall be permitted as open wiring in lengths not to exceed a total of 50 ft (15.24 m) between a cable tray and the utilization equipment or device
The cable shall be supported and secured at intervals not exceeding 6 ft (1.83 m).
Equipment grounding for the utilization equipment shall be provided by an equipment grounding conductor within the cable.
[2002 NEC]
336.10 Uses Permitted. Type TC tray cable shall be permitted
to be used in the following:
(6) In industrial establishments where the conditions of
persons service the installation, and where the cable is
continuously supported and protected against physical
damage using mechanical protection, such as struts,
angles, or channel, Type TC tray cable that complies
device. The cable shall be secured at intervals not exceeding
1.8 m (6 ft). Equipment grounding for the utilization
[2005 NEC]
336.10 Uses Permitted. Type TC cable shall be permitted
to be used as follows:
(7) In industrial establishments where the conditions of
angles, or channels, Type TC tray cable that complies
cable and is identified for such use with the marking
Type TC–ER shall be permitted between a cable tray
and the utilization equipment or device. The cable shall
be secured at intervals not exceeding 1.8 m (6 ft).
within the cable. In cables containing conductors
sized 6 AWG or smaller, the equipment grounding conductor
shall be provided within the cable or, at the time
of installation, one or more insulated conductors shall
be permanently identified as an equipment grounding
conductor in accordance with 250.119(B).
[2008, 2011, 2014 NEC]
Exception: Where not subject to physical damage, Type
TC-ER shall be permitted to transition between cable trays
and between cable trays and utilization equipment or devices
for a distance not to exceed 1.8 m (6 ft) without
continuous support. The cable shall be mechanically supported
where exiting the cable tray to ensure that the minimum
bending radius is not exceeded.
[2017 NEC]
Type TC cable shall be permitted to be used as follows:
336.10(7) Between a cable tray and the utilization equipment or device(s), provided all of the following apply:
- a. The cable is Type TC-ER.
- b. The cable is installed in industrial establishments where the conditions of maintenance and supervision ensure that only qualified persons service the installation.
- c. The cable is continuously supported and protected against physical damage using mechanical protection such as struts, angles, or channels.
- d. The cable that complies with the crush and impact requirements of Type MC cable and is identified with the marking “TC–ER.”
- e. The cable is secured at intervals not exceeding 1.8 m (6 ft).
- f. Equipment grounding for the utilization equipment is provided by an equipment grounding conductor within the cable. In cables containing conductors sized 6 AWG or smaller, the equipment grounding conductor must be provided within the cable or, at the time of installation, one or more insulated conductors must be permanently identified as an equipment grounding conductor in accordance with 250.119(B).
Exception to (7): Where not subject to physical damage, Type TC-ER shall be permitted to transition between cable trays and between cable trays and utilization equipment or devices for a distance not to exceed 1.8 m (6 ft) without continuous support. The cable shall be mechanically supported where exiting the cable tray to ensure that the minimum bending radius is not exceeded.
