gserve
- New Hampshire
Code reads that 2" PVC conduit should be supported within 3' of box,termination,access fitting etc. I have a 2" PVC conduit emerging from the ground to a 90 degree sweep then to an LB. If I measure from the ground to the LB it is less than 3'. Is this considered supported per the code? opinions.
