akacoroski
New member
I want to run a vertical RMC conduit from an enclosure to a cable tray about 10' above the top of the enclosure. NEC 344.30(A) states that you must "securely fasten" within 3' of the conduit termination. NEC 344.30(B)(3) states that you may "support" vertical risers at spcaing up to 16' for 2" conduit if no other means of support is readily available. Are securely fasten and support synonymous in this case, allowing the 3' rule to be bypassed?
