sokkerdude
- Arkansas
We are installing a 3000 amp transfer switch. With a pull section that has the lugs for the normal, load , and generator extending of the respective buses on one side of this pull section. There is 8 set (4-500 mcm) coming out of the slab for normal power. There is 8 set (4-500) coming out of the top for load. And 4 set (4-500 mcm) out of slab from generator. The owner is wanting each 500 mcm supported before being landed on a lug. He has built a rack inside the pull section to support the 500 mcm at 14 in. in front of the lugs. I can't find in code reference about needing to support the conductors. Am I missing something. Any information would help. His rack is limiting the bending radius of the 500's . Thank you
