jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
A customer called us to install some lights she had bought. Some OK but she had a few surface mount LED lights that we could not install. The light has a ballast on top that has to go into the box. Mounting bracket goes in 1st, it is offset into the box about 1 1/4 or 1 1/2 inch. Boxes are so full of wire the bracket will not go in. I have seen this issue before. In new installs, I have always used deep metal octagon boxes with as few wires as possible, feeding from top of box to save space.
I have also seen a few similar lights with no ballast on top. Roughly 6 inches in diameter, a little thicker for having to have the ballasting inside. I looked around several supply houses and stores but didn't see any of them. 1 supply house can order but that is a hassle too.
Big Orange doesn't have them, I haven't had a chance to check Big Blue. Has anyone seen these and know where to get them off the shelf?
