wireday
- New England
- Master electrician
luminaries containing a ballast, transformer, LED driver or power supply is installed on combustible low-density cellulose fiberboard, the luminaries shall be marked for this purpose or it shall be spaced not less than 11/2 inches (38 mm) from the surface of the fiberboard.
Is a ceiling tile a low density fiberboard? Ive always use those T bar clips. I have seen strip lights with spacer brackets that hang lower than the ceiling.
