surface mounted receptacles
dhsvcs
miami
electrician
I am working on a condo remodel that has the shared outside walls made of plastered poured solid concrete. The original wall receptacles are part of an old plastic
wire-mold / plug mold assembly with outlets spaced at 11 ft centers. The g/c is reasonable and willing to groove out base board or work with a viable solution but does not want to groove out the entire wall distance. Do they still make a baseboard wireway system or does someone have any code compliant suggestions ?
Thanx, dhsvcs
So installing new Wiremold is not an option? What are you thinking when you say "baseboard wireway system " something like larger 3000 series Wiremold raceway?
3000jpg.ashx
