Hello...
Opened a panel and found this Approved lightning arrester attached to the mains.
On all the panels I've changed or installed I've never installed one.
I've seen them "on" panels and attached to a two pole breaker.
I research this particular unit and could not find any info on it.
Should I leave it right where it is and how it is?
Should I remove it and have no "surge" protection?
Should I remove it and speak to owner about installing a new one?
(this panel is flush mounted in a finished basement, if the suggestion is to install a new one has anyone ever installed it protruding from a finished wall?? )
Thank you
Thank you
