On Friday my wife called me shortly after a storm had passed and said only half the house had power. I thought lost phase but then my generator should be runing. She said the generator started and ran for 2 min and shut down but while it was runing still only 1/2 house had power
I got home about 1/2 hr after she called and went to the service panel where I found 3 20 amp breakers tripped in the LIPA panel and 2 tripped in the emergency panel. I reset them and all seemed well. I then found a few things in the house that did not come back on, they where powered by GFCI Recpts and the GFCI's had tripped. I then went around the entire house and found all GFCI's has tripped even if nothing was pluged in to them.
When I reset several GFCI's that used to have green LED's to indicate they were OK no longer have a lit LED.
On saturday I was talking to a neighbor and he told me he also had breaker trips, a computer surge strip that smoked, some blown GFCI's and a burnt CO detector. I found in my house my Laser printer is dead as well as the charger for my rechargable light that I keep by the service panels.
Today (sunday) I opened the laser printer up and found the 3 1/2 amp fuse on the incoming AC line had blown in a violent manner, it was a glass fuse and it was all black inside. Replaced the fuse and the printer works.
I should also add that every Traffic Signal in a 3 to 5 mile radius was on flash after the storm until reset by the service company and after reset several had red lamps that did not go out even when the green was on at the same time (green and yellow cycled normaly)
I am involved with several radio sites and they have taken direct strikes yet I have never seen a breaker trip due to a strike.
My neighbor called LIPA in Saturday and they played dumb, guess they do not open them selves up to any libilaty for this. Other than about a 30 second outage they never went down and I did not see any trucks in the area.
Any Idea what happened, I feel lucky I only lost a printer fuse and a flashlight charger (so far) and certanly not going the MOV surge supressor route as I have seen to many of them burn.
