JHZR2
- New Jersey
- Power Systems Engineer
Hello,
i have a situation where there is interest in adding surge and noise protection in a kitchen. The interest is in providing surge/noise filtering for the refrigerator and stove, since both have circuit boards and are big money to repair/replace. Notionally some protection and filtering could help ensure longevity.
The refrigerator has its own dedicated circuit, and the range is one of the two legs of a mwbc that has a microwave on the other.
Neither have good access without removing the appliances, so im not really keen on installing outlet type surge protection. I'd rather put the protection at/near the subpanel which feeds the kitchen - a 50A Eaton CH unit. Easier to see, easier to diagnose, easier to replace, and notionally, if the MOVs fail, could also be easier to keep cool and safe.
Im looking at using something like the leviton 51110, but would like to hear the pros/cons of a device like that versus some others option.
And assuming i ue I use something liked that, the instructions that come with those devices are not very clear, so I have a couple questions:
1) if they are designed for a "Line 1" and "Line 2" connection for a 120/240 split phase setup, can one use such a device with just a single 120v circuit connected?
2) can a mwbc be used as line 1 and 2 in one of these? I.e. Feed it off a two pole breaker and share the neutral conductor? It seems that two separate sets of conductors and breakers may be desired.
On a related note, if one put a surge suppressor outlet in the basement near the panel, and then used the load terminals to connect, any idea how the protection performs with distance from the device, and if there is any difference using the load terminals versus plugging a load into it? That could be smaller/cheaper/easier for at least the dedicated refrigerator circuit.
Thank!
Thank!
