jeff43222
- Minneapolis, Minnesota
I had a troubleshooting call this evening that left me pretty stumped. Single family house, 200A overhead service, feeding two 100A subpanels. Service is fed from a PoCo transformer that is the last one in the chain. The transformer feeds only this house.
The homeowner told me that they are experiencing power surges at random times, and they are bad enough that they showed me all the fried surge suppressors (they've gone through more than 20 of them). Before they installed the surge supressors, they lost a bunch of TVs, microwaves, telephones, etc. They had the dead ones stacked outside. The (many) circuits where these surges have occurred are all over the house.
My first thought was that instead of actual surges, perhaps they were experiencing a loose neutral on a multiwire circuit, getting a nice 245V internally to blow things up. But there were very few multiwire circuits in the panels, and none of the circuits in question was fed by one. I checked every connection in every panel, as well as the meter socket and the service point just to be thorough, and everything was tight as a drum. Voltage readings were all good in the panels and at the several receptacles I checked.
Adding to the mystery was that the main panel already has plug-in surge protection, and the indicator said it was working fine. PoCo has been out, and they claim everything is fine on their end.
The one thing in the house that made me suspicious was the well pump. They said they had it replaced a couple of years ago, and they problems with the surges started a couple months later. The wiring for the pump was shoddy and the grounding on it was poor to non-existent. I wondered if there was a chance the surges were coming from the well somehow and spreading through the house.
If it's not the well, then my guess is that there's still a problem on the PoCo side (e.g., loose neutral) that they will only investigate if an actual electrician calls them.
Anyone care to offer their $0.02?
