Suspended (Drop In ) Ceiling Fixtures
gamecocksc
New member
Columbia
Hello,
I've been browsing this website for a while and now have a situation on my hands that I think y'all could help me out with. First off, before someone attempts to put me 'on blast; due understand that I understand my limitations. I am not a electrician, I am just a restaurant repair person that knows a a little about everything in general restaurants. Most I do is outlets, 2x4 drop ins, wall packs, and the occasional running 120v/240v from breaker box to designed area. However though, a customer wants me to do a job that I am hesitant to accept as I'm personally never seen it done before but maybe you all have seen before as I am always open to a new job idea.
Job: The customer would like ceiling fans installed in a suspended ceiling. I told him the only way I will consider it is if he buys these: (link at bottom).
Now if I use the central chain as a main support (attached to building trusts) as well as supporting the two side edges ( steel wire (thickness similar to 12/10 AWG to trusts), do you believe that will be enough support for a 52 inch fan (no light, fan only).
Q2: The area is about 750 sq ft, he claims he would like 6 fans, I insist on 3 to prevent possible collapse but do you believe if I support it as said earlier that 6 fans could work?
Q3: I believe you would probably find these at a building warehouse, but what are the names of those supports the hook onto the building trusts and have a small loop that chicken wires and supports standard 2x4's?
Q4 (The one related to NEC): Is something like this allowed in commercial application as long as I use proper MC wire, support to trusts? And if you need to know building type, I do not know. Just know that it's a commercial restaurant.
Opinions would be great to hear
Thanks,
Jordan
http://www.amazon.com/Arlington-FBR...415&sr=8-1&keywords=drop+in+ceiling+fan+mount
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
