jaybjeepn78
- Virginia
- Teacher
My family is in the process of contracting out in-ground swimming pool. Although we are using subcontractors and everything is inspected, I personally want to make sure all electrical bonding and grounding is completed correctly. With that being said, I understand that all electrical equipment must be connected to the grounding connection back to the home’s service panel as any circuit would do. I also understand the diagrams that show the use to 8awg bare copper to connect all metal and/conductive components in and around the pool, including the housings of filtration equipment for bonding.
What I am uncertain about is whether or not the bonding grid must be tied directly to the ground connection back to the service panel or any other element of the actual electrical wiring. I see examples online that show this and do not show this interconnection of the ground system and the bond grid.
My question is whether or not the bonding grid is a self-sufficient grid that only ties directly to each metal/conductive component?
in other words, does the bonding grid components get connected to the ground? Or is the bonding simply connect among itself?
thanks in advance!
Jason
thanks in advance!
Jason
