dougthepoolguy
New member
- bucks co pa
We normally bond above ground and inground pools by running a ring around the pool and
connecting at 4 points. We don't have problems with the water, ladder,lights etc.
However, if you have an intex blow up pool (no metal) with 48" of water (permanent installation) the ahj is telling me to bond the
pool. I asked the inspector how. He told me to figure it out.
The next day, i am working on a wilbar above ground pool (54" wall height, steel wall and everything else is resin). I run the ring around the pool, but there is no where to put a lug. He told me to use the wall bolts and bond the wall at 4 points. This got me through inspection, but is not imho correct. Also what is the point of bonding the wall at 4 points, when 2 would do?
Does anyone have a solution or answer to bonding resin and blow up pools?
thank you
doug
thank you
doug
