Re: swimming pool cicuit breaker
Wouldn't this pool light require only 120 volts?
Unless they now have pool lights that use 240 volts. But 680.23 (4) will not allow it if it does run on a 240 volt circuit, And won't even allow it if it is fed from a 240 volt supply circuit
680.23 Underwater Luminaires (Lighting Fixtures).
(4) Voltage Limitation. No luminaires (lighting fixtures) shall be installed for operation on supply circuits over 150 volts between conductors.
[ October 11, 2003, 02:18 AM: Message edited by: hurk27 ]
