powerplay
- In front of a computer.
When disconnecting swimming pool equipment, I seen they had buried a ground plate at the shed, bonded all the equipment and bonded the pool. What was curious to me was that the cable that brought power from the house to the shed panel had an underground connector attached to PVC conduit underground, and the armour removed in the pipe with the inner rubber jackjet intact. The bare copper wire of the cable had been attached to the panel, as well as 2nd system ground plate by the shed panel, pool bond, etc. It seemed to me the bare copper of the cable attached 2 system ground plates together and if house lost the ground, the pool (UFER) would become the main system ground.... What is the proper way to install a panel for pool equipment??? ...Thanks again!
