I have Bonded and wired about 125 Swimming pools but now I have a rather unique project. The pool is inground, formed with uncoated rebar and the rebar does not extend beond the coping edge of the pool. There are also NO ladders, no wet niche housings, railings or any other metal in contact with the water.
Question 1 Does the reinforced gunite or concrete act as suitable contact to bond the water? I have seen the water bonding equipment that goes in the skimmer but if I do not need it I would rather not because I am sure the pool builder would have a problem with me drilling a hole in his skimmer.
Question 2 I have located a #8 bonding mesh from GREAVES in Conneticuit
which comes as a kit to be laid horizontally around the pool which would later be covered by Pavers. I believe that this mesh has to connect at four seperate points to the rebar circumfrence of the pool. Since it is copper #8 cad welded at 12" intervals can this be bonded to a piece of #8 with copper burndys and then down to the grid using a listed lug type device for rebar?
