Swimming Pool Ladder Test For Stray Voltage
Ravenvalor
Hello,
Does anyone perhaps know the protocols for thoroughly checking an entire swimming pool system for safety problems? Any underground scanners that will tell me if stray voltage is coming from an outside source or any source? Check for corrosion? Check all GFCIs? Put volt meter on metal parts at pool to check for voltage? Put Ohm meter on metal parts at pool to check for bonding? Does this include the pool lights? If so, is there a way to test lights?
Thanks for the helpful advice.
Best regards.
