King Electric
- Altha,Florida,USA
I’m seeking clarification on 2017 NEC codes concerning type of breakers used to supply power to below ground swimming pools.
Previously I understood the code to require GFI protection to a pool motor only when powered by a receptacle. The application in question is direct wired to a sub panel with the motor being over 20’ from the pool .
I am unclear as to the use of the term “receptacle “. I have interpreted that as a pool motor that has a plug that is exposed and connects to a receptacle for line voltage . Not a direct wired application in appropriate conduit from motor to panel.
Can anyone shed light on the code concerning this question?
Thanks
Thanks
