Swimming Pool Pump Motors
wmeek
Texas
I need to change out a service panel and found that the 2 motors for inground pool are not on GFI breakers. Should they be on GFI breakers. Pool motors are Approx. 20' away from inside wall of pool.
wmeek
Texas
Re: Swimming Pool Pump Motors
Article 680-22a(5) says if the pumps are provided by rec and rated 15A or 20A 120v-240v single phase has to be GFI protected. What if they are hardwired.
bob
Alabama
680.32 says ALL ELECTRIC EQUIPMENT used with pools require GFCI. Even if the code did'nt require it the safe thing to do is to install CGFI anyway.
wmeek
Texas
Article 680-32 refers to Storable Pools.
This pool is a permanet pool inground.
george t. everett
New York
Prior to 2002 code GFI protection on pool pumps was not required. If it is existing I don't see a problem with leaving it as is. Hard wired pumps do not need GFI protection, only outlets for pool pumps.
