Michael15956
- NE Ohio
Walked away from a quote today because I just don't know enough about swimming pool installs. Existing in ground pool where customer wanted a receptacle & below water light wiring completed. Receptacle is a least 6 feet from pool shell and is fed with #12 UF Cable. Customer wanted this receptacle to feed said light. Light has existing PVC Conduit with insulated EGC wiring already installed but not terminated. This conduit is near the receptacle. This conduit is also embedded in cement. Pool was originally installed in 1995. Can this be completed and complaint without major work?
