- Chapel Hill, NC
- Retired Electrical Contractor
The 2017 Nec has a new article (680.28) and I am wondering if someone can explain what the bold section means. I know there is a section in 411, I believe that has similar wording. What does it mean and how would one know if the unit operates above the low voltage contact limit.
680.28 Gas-Fired Water Heater. Circuits serving gas-fired
swimming pool and spa water heaters operating at voltages
above the low-voltage contact limit shall be provided with
ground-fault circuit-interrupter protection for personnel.
