pasta1234
- Los Angeles, CA
I have a double gang electrical box that has wiring for a double dimmer switch (dual skylark dimmer) controlling two sets of recessed lighting and a timer module that controls a outdoor lamp by the door.
The issue is after upgrading all the recessed lights with LED lights the dual dimmer module doesn't work properly. I assume its because it isn't LED compatible. The problem is there aren't ant dual LED dimmer modules currently available, which is amazing to me
Is there ?
At first i figured id install a larger three gang box and replace it with two individual dimmer switches. Upon removing the box i realized there is wood pretty much on both sides of the box, killing that thought.
Are there any alternatives or creative solutions other than relocating the timer switch ?
Thanks,
Pete
Thanks,
Pete
