Switch gear and transformers
John P Miller
New member
Naperville
My question is... In gear and transformers, is there a code stating that the use of mechanical lugs is ok or do you have to use high press lugs for the incoming service
On my current project we have boxes filled with hundreds of mechanical lugs that have been removed and replaced with compression lugs because it was required by the job spec.
I've never installed mechanical lugs in of that type of equipment, frankly I can not ever recall ever seeing a mechanical lug!
