mstrlucky74
- NJ
Just curious as to how others would wire this? So the lights are all on one circuit. So I know you could bring the circuit/power to either the lights or to the switch but normally you would bring the power to the switch. So the F5's are controlled by one switch and the F7 by the other. So you need a separate switch leg from each switch. Would you run (2) 12/2 from each switch? Thanks.
