JohnJ0906 said:Are you mounting the 4" sq to the panel itself?
Why put switches when you can just turn the breakers off here. This is not the service disconnect of course.Chamuit said:Any problem with putting switches for turning evaps on/off on the side of a panel. Feed from breaker to 4S switch box, then load back into and through panel to conduit feeding evap on roof. As long as, 312.8 isn't violated?
stickboy1375 said:Why even add a switch? just use the breaker, Or are you worried about every breaker being turned off... :grin:
quogueelectric said:Why put switches when you can just turn the breakers off here. This is not the service disconnect of course.
480sparky said:Are breakers rated for that? 240.83(D).
Chamuit said:Nope. Checked that already!!
stickboy1375 said:Thought all breakers made today were SWD rated.
Chamuit said:Don't want the employees opening the panels. Bunch of tards! :grin:
Seriously, I think it's because the IT aircons are in the same panels. Don't want no steenkeeng mistakes. Hmmm . . . wonder what would happen if IT room was at 100?+ for the whole weekend.
Do they need to be?480sparky said:Even if they are, would they be rated to switch motor loads, such as the OP has?
