Jimmy7
- Boston, MA
- Electrician
I've got a customer who is adding new kitchen cabinets in their single family home. Due to the cabinet layout, they're asking me to change a switch and receptacle in a two gang box to a switch over receptacle in a single gang box (Due to space between a cabinet spacer and a window). The switch is on a 15 amp circuit, and the receptacle is on a 20 amp circuit. I'm not sure how many cables are in the box, as I have not seen the job yet, just some pictures. Is it even possible to do an installation like this? Meaning, do you have to simultaneously disconnect both circuits like a receptacle on a multiwire circuit (Two circuits feeding one yoke). I have two different amperages in this situation, so I couldn't use a two pole breaker. Could I use a handle tie between the two breakers (Not sure about the panel make, I think he said it was Eaton)? My other concern is box fill, but I'll know better about that when I see it.
Thanks!
Thanks!
