Not sure I follow your question. Please give all of the pertinent details. What are you trying to do, at what voltage / phase / current, under what conditions etc. etc. etc.
"Switch" is not a very descriptive term, even "disconnect switch" is not that much more helpful. There are literally hundreds of different kinds out there.
does this one mean we can have a maximum of 6 fuses, and each of them can handle a panel or feed the equipment?That looks to me like a three pole switch with only three fuseholders, but two lugs per each side of each pole - designed for paralleling two conductors per line.View attachment 19892does this one mean we can have a maximum of 6 fuses, and each of them can handle a panel or feed the equipment?
Maximum of six disconnects, not fuses.View attachment 19892does this one mean we can have a maximum of 6 fuses, and each of them can handle a panel or feed the equipment?
Square D has four and six pole "Safety switches" in their catalog.
Don't really know if there is a specific intended use for them though, never seen one in the wild either.
You wouldn't be allowed to put fuses in the neutral in a fused disconnect - solid jumper could be used I guess, and have even seen that on corner grounded delta systems.4P used for where you need to switch the neutral, such as a hazardous location.
6P used as motor disconnect for a two speed, two winding. Used several of em back it the day before VFD's were common.
MTW
Yes, we agree.that pic posted, its a "3pole fused" disco.
