Switch to recess lighting - help with Romex
Hello all, I need some help. I want to switch from two down lights to four recessed lights. I took the main light down (L1 in image below) and was meet with the wiring you see on the right. The second down light is turned on by the same two switches (S2) as the primary light. However, I'm not sure where the wiring is coming from (I'm assuming L1). Can anyone tell me what they make of this wiring (I had to insert a link, don't know how to insert an image)?:
Wiring
Wiring
Are you an electrician?
No access to your Google Drive
