JerryHonolulu
In conducting an audit of installed electrical apparatus at a commercial office building, I recently encountered something I had never seen before.
The secondary switchboard is connected to the 480Y/277V secondary of a 750 Kva oil-filled transformer through a 1000A main breaker. This is an old FPE system, consisting of a dual-feed primary, metering, fuses, the transformer, the secondary main (air circuit breaker), and the secondary switchboard. The date of installation, as far as I can determine, was 1957.
At the bottom of the secondary switchboard is a manufacturer's ID tag, riveted to the sheet metal panel. This tag states that this switchboard is for use on a 208Y/120 volt system!! This has been in service for an estimated 56 years.
Your comments and observations, please.
