the individual breakers in the distrbution section exploded one after the other,until there was nothing left,the explosions only stopped when the POCO killed power....
Explode translates to pieces of CB flying in random directions. What could cause individual distribution CBs to explode?
Certainly not a fault on the distribution bus.
Certainly not a fault after each distribution CB. Not only does it seem unlikely there would be a revolving fault hitting each of the distribution CB in order, but even if there was a fault on each, why would they explode? Why not just open under fault current?
You said "project". Is this new work? Or been there a while?
And the fuses didn't blow. You may wish to check the rating on the fuses. I'd probably even be checking if the incoming cabling was connected to the right spot.
And the xfm primary didn't trip. Let's see, POCO xfm, cutouts fused at maybe 600%, no differential relay. Maybe it wouldn't trip.
What's left? Even if the POCO installed a full sized xfm, that's still only a 1500kVA - probably less than 40kA SCC. A fault would have opened the fuses or distribution CB.
I'm really puzzled by this "explode" thing. If you aren't screwing with them, CBs don't just explode. Just curious, what kind of CBs were these?
How about a high voltage, internal xfm failure, on the xfm sec? I've never seen one, nor any papers on the forensics - so I can't comment on if that would cause the CB to explode.
cf
