slice
- Massachusetts
Hello all I am working on a large residential project and am designing the main switchboard. The load per article 220 is around 600A for each of two meter banks and one house panel. I am planning on supply each with an 800A Circuit breaker in a main switchboard. This switchboard is directly connected to the utility transformer secondary. My question is it allowable to install a 2000A switchboard for the above scenario? I believe it is acceptable since the calculated load is less than 2000A, just the sum of the breakers is larger than the rating (2400A). Also am I correct in that a main breaker is not required for this case (even though the combined breaker ratings exceed the switchboard rating)?
