shaner
- Olathe, KS
Hello to all,
I have an IDEAL SureTest ArcTester 61-058 that I use during inspections.
The other day I found some duplex outlets with the bottom halves switched at the door to the room (basement living room). With the switch in the "off" position, the tester showed there was an "open neutral". But the tester light was very faint - not like an open neutral usually looks on the tester. When the switch was turned to the "on" position the tester glowed bright with a "correct wiring" indication.
What condition is causing this faint "open neutral" indication when the switch is in the "off" position?
