Thomas Underwood
Is it permissible to switch from a 4 wire Genset (including neutral) through the switched neutral ATS to a 3 wire delta fed transformer?
2014 NEC Handbook Exhibit 250.13, pg. 179 indicates in the picture that the transformer is 4 wire feeding a neutral from the other side of the ATS. Nowhere does this exhibit or text in these two pages indicate in writing that the transformer must feed a neutral using a wye from the other side of the ATS. It is only the picture in the exhibit that indicates this.
