switched outlets
dwellselectric
Inactive, Email Never Verified
I was making up a switched outlet the other day and I always splice the blacks with a tail and reds with a tail and I also do the whites. Now I was curious how many people splice the whites? I just think it's a better practice in case the outlet is ever changed the whites are not broken while the hots feed through. Is this in the code and if not you think it should be?
I also pigtail everything in a cable-in, cable-out receptacle outlet box.
And a longer rough in and more wirenuts.. I have wired homes for 30 years and I am called back on many of them and have never had an issue. I have had issues with wirenuts
The single greatest value of the pigtailing method is that I can make up the entire circuit as part of the roughin, and yes it takes time, and then I can install the AFCIs and heat up the branch circuits and check continuity, and wait for miss-wire tripping.
I second that it makes for a quicker, and simpler, trim out.
Unless I need GFCI protection ahead, I pigtail all my receptacle boxes, makes the trim-out easy and less painful.:D
