hey guys, I was wondering what the code is for a dwelling as you come in the door of a room what is the max distance that a switch for lights can be away from the door? One more thing, when strapping mc cable is it legal to use a one hole strap as a mechanical connection to the wall and then use a black tie wrap or steel tie wire around that one hole strap to secure a bundle of mc cables running in a wall as a means of strapping and support?
There is no requirments in the NEC as to where the location of lighting outlet switches are to be located. Check for local and ADA codes.
Again, I would leave this up to the AHJ as to whether or not your suggested securing method is acceptable. Otherwise, if done in a neat and workmanlike manner, I don't see a direct code section prohibiting this.
thanks for the reply, it had crossed my mind to look at the ada requirements and the handicap codes, you are probably correct, it is most likely a ahj situation, i will look into it.
