Code Changes for 2011: There will be a lot more three & four conductor Romex (NM) cable sales because of this code change. Future two-conductor switch loops will need an extra conductor as well as 3-way switch runs needing an fourth conductor. What does one do if the extra conductor is not used for lighted switches or electronic switch devices ? I suspect wire nuts is the answer.
