nadprosper
OK.....so an architect designed a bathroom where there is a tub by the door. The switch box is shown to be about 2 1/2 feet from the edge of the tub. We could move the switch to the other side of the door but due to the design of the room....that would still leave the switch around 3' from the tub. There is no other good option barring moving the tub ( not gonna happen ). So, the question is, can I GFI protect the switches in order to make it code compliant....and where is that stated in the code. In addition, they want to put a pendant above the tub......if that fixture is low voltage, then can I install it within the 'wet location' only zone? Thanks in advance.
Nad
Nad
