When considering Double-ended MV M-T-M switchgear is it standard practice to have PT's located on line side of main breaker, load side of main breaker (bus PT's), or both?
I guess ideally it would be best to have PT's on both sides but this may not always be feasible due to cost and space limitations? I believe with a tie-breaker you need to have bus PT's so that PT power is available to relays, etc... when bus is fed through the tie. I cant seem to think of a good reason to require PT's on the line side of the main other than to be able to see that there is incoming voltage at the line side of the main breaker.
For my question I'm ignoring any PT requirements for synchronization.
