FaradayFF
- California
Hello folks,
Are low-voltage switchgears in the US built to UL 1558 rating by default? There is an IEEE C37.20.1 standard that is used to govern switchgear construction. I wasn't sure if UL 1558 adherence needs to be specified in the tech spec for a switchgear, or whether it is assumed that most US vendors such as Eaton, Square D build the switchgear to the UL 1558 standard already. I know that UL 1558 provides for a robust construction, but it could also be expensive.
Thank you for your thoughts.
EE
EE
