switching exhaust fan with 12/3
iwirehouses
I know that inspectors arn't very sure about 12/3 circuits themselves. Other then the small appliance circuit, using 12/3 is kind of up in the air. I'm wondering though, if anyone has ever had a problem with switching an exhaust fan/light combo with 12/3 or the equivelent. The fan may have heat and a nightlight as well. Instead of running four 12/2 cables, I think it makes much more sense to run two 12/3's, am I wrong?
Why not install a short section of conduit, and install enough conductors (six) to do the whole job?
Black-White-Red-Blue-Orange-Green
No you're not wrong. I have always tried to consider cost and resource savings in a wiring lay out and this is a method I would (actually have) definitely use.
Roger
I normally have 12/4 MC on board and if that where not enough conductors a length of 1/2" flex would would work fine.
I can't imagine four - 12/2s entering those small JBs
We use 12/4 NM cable for these applications. One cable in the switch box and one in the fan. Anything more than that in the minuscule fan box is a nightmare.
We have 4-wire romex, but the problem here is you have 4 different switched loads and there ain't enough conductors present to do the job.
You need 4 hot conductors, and a neutral, plus a ground. ..:wink:
Very few residential guys even own a bender.Mc is ok but there is 12-4 nm now.Residential is about speed so i sugest a couplke runs of 12-3 or 12-4 nm.Now if thats too confusing to make up then perhaps we have bigger problems.Phase tape should do the trick
iwirehouses said:
IInstead of running four 12/2 cables, I think it makes much more sense to run two 12/3's, am I wrong?
Wouldn't that be a violation?
I asked this question over a year ago in regards to a fan/light/nightlight unit(Hunter).
I can't remember the article number....Infinity may have answered it :confused:
The only violation might be tying all the neutrals together in the fan unit. If you are running two neutrals in two cables, the loads on the read & black need to correspond with the neutral in the cable. 300.3(B)
Be carefull there bucko! iWIREDhouses for 30 years before becoming an inspector!
So what?
LOL
No offense, but that sounds like the 'ol "That's the way we always do it" reply
:D
The bigger problem is in the switch box. You can't use a normal nail on without running into box fill issues, you have to use something bigger with a P ring.
I just ditch the stack-switch that comes with the unit and install separate ordinary toggle switches for each load. Plenty of room in a 3- or 4-gang box!
Now, there's an idea. :)
And I can't imagine running more than one grounded conductor if not needed.
So how does the power get in? :confused: :grin:
Okay, so run a 12/2 and a 12/3, and color one of the whites blue.
I wouldn't run more than a single neutral in this type of install, unless there was a heat load requiring a separate circuit, and then I'd look into making it a MWBC.
Whether I need two 12/2's or a 12/2 and a 12/3, I color one of the whites to use as an additional switched leg (re-coloring prohibition be damned).
