I have an existing application where fluorescent egress lighting has been installed (with a normal ballast and an emergency/battery ballast). This lighting is not switched. The owner would like to switch the egress lighting with the normal fixtures. Is there any code requirement that would not allow the egress lighting to be switched from the nearest "normal" fixture, i.e., bring a switched wire from the nearest normal fixture to each normal ballast in the egress fixtures? The emergency/battery ballast would remain connected to an unswitched source (from the same circuit as the "normal" fixtures), so in case of normal power failure, the egress lights will come on.
My main concern is running a neutral and unswitched hot into the fixture in one conduit, then in additon to a switched hot with no neutral in another conduit into the same fixture. I've been looking everywhere I can think of in the NEC, and haven't come across anything. Am I missing something, or overthinking this?
