Art_R
- Long Island
The question is: do you have to run the switch leg (dropback) of the pool lights in conduit all the way from the switch to the faceless GFI feeding the first deckbox? If most of that run is in a basement can't I use NM back to the panel to turn off the hot leg as long as we maintain a continuous ground and return?
Does it matter if it is new construction or a remodel?
Also what if I wanted to use a x10 relay to switch off the lights. What would be the difference of this (as a safety issue) and using another Jandy relay.
I am getting used to the installation methods of my new shop and it differs from the previous.
Thank you in advance for your comments and insights. I did search previous posts back for about 30 pages and did not see this question addressed.
