What are the requirements for a recessed can having to be switched through some sort of ground fault protection? Specifically, what are the rules for putting up cans directly above showers (residential), can they be put directly above showers in the first place, and what are the specific distances specified before the can has to be GFI protected?
Also, if you have a dedicated recpt. circuit into a residential bathroom, can you run any lights off of that circuit. I know it would be obvious to run a lighting circuit in a new construction application; however, I was wandering if you can switch one can through the load side of a GFCI receptacle which is on a dedicated bathroom recpt. circuit.
Basically, I would like any information anyone has on lighting in bathroom/wet locations and any rules that apply.
Thanks in advance
FIRST POST
Thanks in advance
FIRST POST
