Sylvania Electrical Panel
chris1971
Usa
I looked at a job today with a residential Sylvania panel. Do they still make branch circuit breakers rated for this panel? If so, what brand?
chris1971
Usa
Would the CH be UL approved for a Sylvania panel? I believe the Slyvania panel I looked at looked like mini breakers whiche were light blue in color.
peter d
New England
Sylvania is completely obsolete and there is no direct modern replacement available. I could check into a Cutler Hammer "Classified" Type CL breaker to see if it's listed for use in Sylvania.
norcal
Sylvania became Challenger & as said before, Sylvania = Zinsco.
Sylvania did make 2 styles of breakers 1 was the infamous Zinsco design, and the other was the common 1" wide breaker that is refered as "interchangeable" by some folks....
Sierrasparky
USA
Electrician ,contractor
NEW Breakers are available quite expensive about 40 - 50 bucks
UBI and T&B ( I heard T&B sold the line)
LarryFine
Henrico County, VA
Electrical Contractor
The latter of which should accept Cutler-Hammer type BR breakers.
